Hyundai Veracruz This crossover combines the functionality of a minivan in a sleek exterior with luxury qualities.
Valve Cover Gasket Leak on 08 Limited
Old 04-05-2017, 04:04 AM
luvmycruz's Avatar
Question Valve Cover Gasket Leak on 08 Limited
Has anybody had any dealings with Hyundai when the valve cover gasket leaked oil onto the AC compressor and caused it to fail after the warranty ran out? There was a recall in 2014, gasket was replaced, but it still leaked. Hyundai just replaced the gasket again, but would not replace AC compressor.
Old 07-04-2020, 06:07 PM
Raphael Saibel's Avatar
Default Solution for valve cover leaks
The solution is simple: change the valve cover with a new one, or just pass it on a plain. I've changed the valve cover seal 3 times, 3 alternator rebuilt, until I discovered how to fixed it. Please share this solution in another forums. It's the only way to fix it.
Old 07-05-2020, 06:43 AM
There is always a reason for repeat problems . What was the reason the valve cover needed to be replaced here, thanks.?
Old 07-05-2020, 12:30 PM
Warped, deformed, I don't know the exact technical term to express. I'm brazilian. I passed a planer and it's fine since two years or 50000 km ago.
Old 07-07-2020, 06:48 AM
Good tip, thank you .
mustangdude
08-31-2014 01:51 AM
silvertones
07-28-2014 10:11 PM
Ricklee64
01-27-2012 12:58 PM
Kandi_Lady
08-04-2011 12:42 PM
cslsxpistol
12-09-2005 12:44 PM
Quick Reply: Valve Cover Gasket Leak on 08 Limited
