Issue with accelerating...sensor? Code P1511
Okay..going to follow up on this finally. Will be great info for the next person this happens to. I went in 2 weeks ago digging into the problem on my sister's car. I got it to act up for me twice. First time, threw a CEL for the APPS. Cleared it, drove it again, acted up, this time threw a CEL for the TPS. I went ahead and replaced the APPS/Throttle linkage (the linkage/spring comes as one unit with the APPS already installed on it). This has cured the problem. So, in the end, all the wiring was fine, and the culprit was indeed the Accelerator Pedal Position Sensor!
So my question is, before I spend $150 for a APPS which I think is the problem, does anyone know if there another problem out there with these with a different sensor, or if there is a reburn for the ECM for this issue or something?
I would like to see if there is a common problem out there with these if anyone knows here before I take a $150 guess you could say.
Thanks for your time and for the free space!
If it was my car, I'd bite the bullet and spend the $150 for the sensor and take it from there.
I have come across this TSB from Hyundai which better explains DTC codes for the electronic throttle system: http://www.hmaservice.com/files/331/.../06-36-003.pdf. I hope it helps.
tim.penfold
Mar 20, 2008 02:32 PM
