Hyundai Entourage This minivan boasts of being one of the safest vehicles in its class.
Changing rear wiper blade
Old 01-27-2011, 09:11 PM
Kodge's Avatar
Default Changing rear wiper blade
Simple task, simple question maybe - but can anyone give me an idea of how to change the rear wiper blade? Picked one up from the dealer when passing by (found a thread about cheaper options a few minutes ago...), checked the manual and it suggest the dealer do it to avoid damaging parts.
Old 01-28-2011, 07:41 AM
If you bought a factory blade it actually replaces part of the arm itself. Just lift the arm slightly and pull the blade and arm off away from the pivot point. Look at the replacement blade and you will see.
Old 01-29-2011, 10:39 AM
Kodge's Avatar
LOL, thanks for the info Nova - that took all of 20 seconds. No idea why they don't explain that...
Old 02-09-2011, 07:48 PM
zachunderwood's Avatar
Thumbs up Here's a DIY for changing the rear wiper
Remove the cover from the rear wiper blade
Size:  29.3 KBName:  Wiper2.jpg
Step #2 .. Use a 12 mm socket to remove the nut in the middle and pull off the wiper arm. Now, this is just like changing the blade on the front wiper.
Here's a quick photo of the receiving arm to hold the new blade.
Old 02-09-2011, 08:12 PM
You do not have to remove the wiper arm from the vehicle to change the blade.
Old 02-09-2011, 09:06 PM
I'm sure you're right on that. I just thought that with my luck, I'd end up breaking something.
Old 03-22-2011, 07:06 PM
You're lucky you did not twist the nut off top of the shaft..
Did a Tucson today, raise blade off widow, pop the tiny blade off, snap new blade on,,,,,, all done
Old 03-24-2011, 03:09 PM
Here's the pics from my van. Just pull the arm up off the glass and while holding the rear part of the arm, pull the front half off.
Attached Thumbnails Changing rear wiper blade-sedona_wiper_1.jpg   Changing rear wiper blade-sedona_wiper_2.jpg   Changing rear wiper blade-sedona_wiper_3.jpg
ZombieHunter
12-09-2013 09:05 AM
wingsuitchick
01-27-2013 08:18 PM
JL07Santa
03-28-2011 07:01 PM
exploding_nun
06-26-2007 08:41 AM
ridingtoohigh
03-20-2007 08:12 AM
Quick Reply: Changing rear wiper blade
