Cost of Thermostat Assembly for Sonata
Old Mar 31, 2023 | 04:32 PM
Jm9090's Avatar
Default Cost of Thermostat Assembly for Sonata
Hi,
Apparently my 2015 Hyundai Sonata needs a thermostat assembly, and the repair place we took it to says the part is $693 plus $400 labor. Does that sound correct?
Thanks.
Old Mar 31, 2023 | 07:18 PM
Where did you take it to get that estimate?
Did they tell you why the figure was so high?
Old Apr 14, 2023 | 08:25 AM
oragex's Avatar
It's extortionate. rock auto has the complete housing for $150 (make sure you get the correct part for you, link is only an example) 2015 HYUNDAI SONATA 2.4L L4 Thermostat Housing / Water Outlet | RockAuto
Normally it's only the small thermostat that fails, but when the plastic housing is removed it will usually crack and need replaced. Otherwise the thermostat itself is about $40
$400 labor also seems insane to me. Accessing the housing is 30 min or less, draining the coolant is 30 min. At most 1.5-2h job
hyundaigypsy
Nov 27, 2017 08:46 AM
germain
Mar 22, 2017 09:29 AM
LooseNut
Mar 24, 2010 08:24 PM
Grog32retired
Dec 21, 2008 02:07 PM
MSPrentiss
Dec 21, 2008 01:01 PM
