1.6 2012 accent
1.6 2012 accent
Have 2012 accent had a spun rod in it but ran great so put a long block with injectors in it but all the rest of the stuff came off the old motor got it all back to together now it has a bad spot about 3500 rpm in gear or out. It sputters about 3500rpm once you get pass that it will run up.to 7500 rpm I dont know what is wrong with it it does have a code of po030 and everyonce in awhile it kicks the knock sensor and crankshaft sensor code
First I hope you mean a code P0300 !
When you say long block, where did you obtain it ?
The reason I ask is, if it is not exactly as your old engine sometimes the reluctor that sends signals to the crank sensor con be different from your original engine.
It may not be anything like that, but swapping engines these days can get pretty complicated.
stublu22
07-20-2007 08:30 PM
