2010 Accent washer pump connector
I need to know where to get a new electrical connector for my 2010 Accent GS washer fluid pump. Apparently someone replaced it before with a generic model that came pre-wired so they cut off the connector and spliced in the wires. I already have a new pump and I'd rather not solder wires directly to it. Unfortunately I'm having trouble finding out exactly what connector used to be there.
Thanks in advance for any help someone can offer.
Most times pumps come with wires of 2 different colors. Example; red goes to positive feed and black goes to ground.
The two wires you have , from the vehicle should have one a ground and the other a source of power. This is easily confirmed with a voltmeter or test light.
What colors does your replacement pump have,?
