Hyundai Accent 2009 Transmission fluid temperature sensor
Hello All,
I have a Hyundai Accent 2009 model. It becomes long for the the gears to change and my Mechanic says it's the transmission fluid temperature sensor. Can anyone help me with how to get one? Thank you
Before doing that, can we ask,
Does the problem happen when the vehicle is only cold or only hot ?
If it only happens with either one of those conditions It is possible a fluid temp sensor could be involved.
If not, a faulty vehicle speed sensor could be causing the problem.
Just throwing parts at a problem can get expensive and not , "Hit the nail on the head so to speak".
You might consider a second or third opinion before spending a lot of $$$. There are tests that should be considered to confirm just what is going on.
