to HyundaiTech - thank you!
Old Aug 7, 2010 | 12:36 PM
zero_gravity's Avatar
Banned
Default to HyundaiTech - thank you!
if you see this, just wanted to say thanks. a while ago you mentioned that the odd no start problem could be a bad connection with the crank position sensor. i think you were right on the money with that one
finally got the time to check it out and i was quite happy at how easy the connector is to access (right by the exhaust manifold) and sure enough the pins were discoloured and i notice how easy it would be for moisture to enter this connector. so i got what is hopefully a free fix. clean up the two pins with a small file, dielectric grease on the pins, then sealed the connector with RTV silicone. with any luck, that should take care of it.
only problem is i won't know until the colder weather hits late into the fall
either way, thanks for the tip! looks like it may have helped me out!
MannySarria
Jul 22, 2024 11:51 AM
czaka
May 14, 2008 10:38 AM
Nov 18, 2005 03:39 PM
