No start
Old 05-21-2018, 11:03 PM
DDR's Avatar
DDR
DDR is offline
Default No start
08 ACCENT ran 30 min or so before shut down then no start till cooled off. Replaced fuel pump and it went to no start at all. Replaced crank sensor and camshaft sensor still no start. Fuel pump I hear come on but no start. Sprayed started fluid in throttle and it starts but shuts down. Any ideas of what I should check for. Stuck on problems
Old 05-21-2018, 11:53 PM
avisitor's Avatar
Seems like you replaced the fuel pump and cause a secondary issue.
Many times when someone replaces the fuel pump they forget an O ring from the old pump.
So, even though the fuel pump runs, it can't build up enough pressure or flow to start engine.
You will need to address that issue first before you can go back to fixing the first problem
And if it was the fuel pump then that would fix it all.
If you can get a fuel pressure gauge on it then it will help tell you if that is the issue at present.
Good luck
Old 08-23-2018, 11:19 PM
ampmadscientist's Avatar
Having a very similar issue, let me know if you think of anything else...
Old 08-24-2018, 04:34 AM
Agree,you need to confirm correct fuel pressure !
Caleb Green
07-18-2019 04:15 AM
makowski306
11-07-2017 03:19 PM
mash4077
09-20-2016 07:44 PM
tjjolle
01-13-2015 10:49 AM
dj34
01-30-2007 12:04 AM
Quick Reply: No start
