Hyundai Atos Predominantly sold in Europe, the Atos is the smallest of the Hyundai lineup offering European sub-compact styling.
steamy window and one electric down
Old Oct 28, 2008 | 10:14 AM
danieleonharper's Avatar
Default steamy window and one electric down
hi
also my front windscreen and side ones mist up very easily when driving and the air lower doesn't seem to blow high up enough to sort it so i use a cloth and then it isn't clear
electric window dirvers side cable broken - any idea how easy and expensive to replace system
thanks
dan
Old Oct 31, 2008 | 06:40 PM
jsinton's Avatar
Banned
Default RE: steamy window and one electric down
If your windshield is misting up, it's possible your heater core is leaking fluid. Is your antifreeze low? As far at your broken window, it depends if the window is physically broken or the electric motor is not working.
Old Nov 15, 2008 | 05:51 AM
will check anti freeze - just seems the air does not blow high enough up the window to demist it
i opened the door - the cable has broken but the motor works - looks like a horrendous job to attempt..
Old Jan 14, 2009 | 05:03 PM
got a repair kit (pulley etc) for electric window but given there is no haynes manual for an atoz does anyone know how to get the system out of the door!?
i took the panel off and could not work it out
thanks
Old Jan 14, 2009 | 05:37 PM
jsinton's Avatar
Banned
Take the other side apart and see how it works. It will guide you on how it works.
Old Jan 14, 2009 | 05:39 PM
that doesn't solve the problem which is HOW to get the system out of the door in the first place!!!!
Old Jan 14, 2009 | 06:13 PM
jsinton's Avatar
Banned
When you say the "cable is broken", do you mean the electric wires going to the motor?
Old Jan 14, 2009 | 06:29 PM
jsinton's Avatar
Banned
This is the diagram from an Accent here in the US. Does your Getz look like this?
Old Jan 15, 2009 | 09:48 AM
no i mean the cable is broken - i have a replacement kit
thanks for the diag - not sure if it is the same as the atoz - will take a look
pete c
Sep 12, 2013 04:58 PM
Jack Seeders
Apr 20, 2013 08:03 PM
KnifeyMcShanker
Jan 27, 2009 05:01 AM
shermanr
Feb 10, 2006 12:56 PM
drummerfromhell
Oct 14, 2005 06:11 PM
