2015 Window not moving-Regulator Cable broke
Old Jun 9, 2020 | 05:46 PM
burnsr's Avatar
Default 2015 Window not moving-Regulator Cable broke
Front drivers side door makes a grinding noise when trying to move the window up/down. Took door panel off and motor and see that the cable is broken. From what I can find this can be resolved by replacing the window regulator assembly. Trying to find a part# has been an issue. I found 82471-3Y010. I am pretty handy, is this a do it yourself thing? Car is a couple months over 5 years old so guessing this isn't a warranty issue.
Any advice will be appreciated.
Thanks
Old Jun 10, 2020 | 05:17 AM
Not aware of any warranty issue.
Part easiest to replace if you stay with OEM (Hyundai) parts.
Old Jun 10, 2020 | 06:59 AM
burnsr's Avatar
Thanks for the reply, warranty for 5 years so just missed it. I am an engineer so I feel comfortable taking on most projects. I do research, YouTube videos etc. I can't find anything on the 2015 Elantra regarding this part replacement. I took the door panel off and then the window motor and saw the cable damaged. I understand not as simple as replacing cable, entire assembly must be replaced. I did not have time to pull the regulator assembly off since my daughter needed her car. I was happy I was able to get window back up. I found the regulator assembly for about $219. Wish I could locate some installation instructions...going to dig deeper today.
Old Jun 12, 2020 | 09:40 AM
avisitor's Avatar
Probably looking at older models will give you a good clue as to how to proceed??
(youtube)
ShortBuSX
Nov 7, 2020 08:46 PM
steve341
Aug 20, 2018 05:39 AM
danieleonharper
Jan 15, 2009 09:48 AM
jubalhawg
Jul 9, 2007 08:31 PM
smokethemusic86
Sep 18, 2006 07:55 PM
