Electronics dim
#11
You do the best you can under the circumstances and hope it takes care of the problem.
Without the proper tools to confirm alt output, you are shooting in the dark. Hopefully you can buy some time with other less expensive checks and you never know , it may solve the problem. You would need a pretty hefty amp meter to confirm 130 amp output, but even half that amount should keep the lights from dimmimg.
#14
I just started having the exact same problem with my 07 Entourage. If you see this, would you mind describing a little more about the ground wires you tightened up (anything that will help me do the same)? Thanks!
#15
It can be a slow process but for me it had the required results
Andrew Rehmert
03-05-2020 04:14 PM
seffyroff
06-19-2017 11:53 AM
USAFTankDiver
09-21-2012 08:45 AM
