Bizarre electrical problem, please help!
Old May 19, 2009 | 08:58 PM
  #11
browneyedangel85's Avatar
Well...... as I said early they went out on my way to work. After I got to work this morning. I changed the fuse with another fuse out of the fuse box. I think it was the one for the cigarette lighter. It blew right away I thought it was too small amp wise. I called the dealership they said I needed at least a 10 amp fuse. So I went to Autozone on lunch and grabbed a pack. Put it in it seemed okay. Pulling back into the parking lot of work went to use my turn signal again didnt have any. The fuse was blow again. So I changed it again. When I was leaving work to come home changed the fuse again. When I got home the fuse was blown again. I dont understand what is wrong. I am using a 10 amp now which is what it says on the fuse panel that it takes so why does it keep blowing. Should I try a 15 amp in the morning?
Old May 19, 2009 | 09:00 PM
  #12
I'll have to check that tomorrow after work. Hope it works. Cant afford to have anything major wrong it. I really wanted this car and thought it was the car of my dreams now it seems like my nightmare. Havent even had it a week and the dealership has been told me to kiss off in a not so nice way.
Originally Posted by jsinton
Turn signal relay should be in the fuse box under the hood.
Old May 20, 2009 | 04:35 AM
  #13
jsinton's Avatar
Banned
Turns out you might have one of those turn signal relays on the body control module computer. It's a real PITA to fix, or just replace the BCM for $1000. I suspect that's why the dealer told you to "get lost".
Old May 20, 2009 | 06:39 AM
  #14
Well, I'll try looking in the fuse box under the hood for the turn signal relay. Thank you for all your help
Old May 20, 2009 | 10:20 AM
  #15
Could a bad bulb cause all these problems? I dont think but I am just trying to figure this out so I can fix it.
Old May 24, 2009 | 07:52 AM
  #16
jsinton's Avatar
Banned
Here's a really good thread with a post from Novaresource on exactly the steps necessary to replace the turn signal relay on the BCM, it gives you an idea of what a pain the the **** it is:
https://www.hyundaiforum.com/forum/s...n+signal+relay
Old May 24, 2009 | 12:28 PM
  #17
Thanks for all your help. The dealership finally decided to do the right thing.....i had to call an attorney about the lemon law and also contacted the bbb. but they are finally fixing it and they are even comping me a rental car. Turns out it was their fault actually.....when i got the car the clock was broke. They said they would replace it but in the mean time they would disconnect it. Turns out they just left the wire hanging and it shorting the wiring harness.
Old Oct 20, 2009 | 02:25 PM
  #18
roostersmith's Avatar
Default More electrical weirdness cruise control
My cruise control died. What I discovered was that my tail brake lights had blown, thanks to my wife following me one night, and the circuit for the cruise control is in series with the brake lights. Once I replaced the brake lights the cruise control works again...
Old Aug 23, 2024 | 02:31 PM
  #19
Beve's Avatar
Default Help
Originally Posted by paganman7
Thanks for the help Ken.
It turns out that when I wrote "I checked every fuse in my car", I seemed to overlook a couple, including a blown fuse labeled clock (in the interior fuse box). I replaced that 10 amp fuse, and everything worked! Hyundai should relabel that fuse the "clock/dash light/dome light/radio/remote keyless entry" fuse. Am I the only one who finds it absurd that one fuse controls all of these systems?
At any rate, all is well. Thanks again homie!
By the way, I called the dealer, and they told me that the wiring harness underneath my seat is an airbag diagnostic port. Apparently, that's where the dealer installs their diagnostic equipment to examine airbag functionality...just so you know.
Please tell me exactly where that fuse was, I'm have the same problems with my 2005.
Thanks
pauld1980
Dec 25, 2014 03:18 AM
benjaminainley
Jan 27, 2011 01:24 PM
mhfry1
Sep 29, 2010 02:49 PM
03BlackonBlack
Dec 31, 2008 03:28 PM
senso
Nov 24, 2006 10:16 PM
