Where's the dang drain plug/filter?
First post other than my "hello" in the new members area.
Trying to become a little more self sufficient and save a little money so I figured I'd start by doing my own oil/filter changes. Did my daughter's 2004 Mustang without too many problems. Then the fun began. Absolutely could not get the drain plug out on my 1998 Volvo wagon - some gorilla must have tightened it at the last oil change.
Next came my wife's 2005 Santa Fe with the 2.7L V6. I must have spent 30 minutes crawling around under that thing with a flashlight and I simply could not find the drain plug or the oil filter. Am I a total moron (OK don't answer that) or do you have to remove that whole skid plate thing to get at anything underneath this model? The bargain basement lift I have didn't get the vehicle up very high so I was pretty limited to my movements but like I said, I pored over the belly of that beast with a flashlight!
OK, I'm ready to take my abuse!
RE: Where's the dang drain plug/filter?
The oil filter is on the side of the pan which faces the front of the car:
The oil drain plug is located towards the rear of the pan (between bolts 7 and 8 in the picture below):
So you're saying I should be able to see both of these without removing anything else? Do they look weird or disguised or something? I swear I looked at every inch of the engine bottom with a flashlight and didn't see them!
Ahhh...now the plot thickens! I had a feeling I wasn't seeing everything. I guess I'm going to have to get a better jack to get the vehicle up higher in order to get that pan off and then be able to get at stuff.
Thanks! [sm=hail.gif]
Hi
I am new to the site and was curious if anyone know if this would be the same chart for a 2008 Tucson with V6? My oil filter is very easy to access but not sure where the oil drain plug is?
Any help would be greatly appreciated
thx1971
06-17-2009 07:19 AM
