Steering wheel pulls when accelerating
Old Jun 16, 2018 | 11:41 AM
Roz's Avatar
Roz
Default Steering wheel pulls when accelerating
when I'm driving the steering wheel pulls to the left when I'm accelerating and pull to the right when I'm decelerating. I've had a wheel alignment!! Any idea what it could be
Old Jun 16, 2018 | 12:46 PM
avisitor's Avatar
It could be tires or brakes
Hard to tell from my computer keyboard
And from what little information there given
Old Jun 17, 2018 | 07:31 AM
Roz's Avatar
Roz
ok I'll have tires and brakes checked
Old Jun 17, 2018 | 11:50 AM
eddyk's Avatar
I have the same problem on my 2005 Santa Fe. Thought it might be bad ball joint or tie rod, ...but no. It seems that right after I had an alignment, I started to experience the problem. I think that the mechanic who did the alignment had to "muscle" the tie rod nut so much that he messed up the front rubber bushing on the control arm. Jack up one side at a time with the tires on, grab the tire at the 9 and 3 o'clock position and wiggle it inside and out while looking at your control arm. If the control arm moves at all horizontally that may be the source of your problem.
Old Jun 17, 2018 | 01:37 PM
Keeping in mind that when accelerating the engine mounts have to move one way and when decelerating the mounts go in the other direction. With front wheel drive the transaxle is mounted to the engine and torque is applied and released to the front wheels. The object is to determine why the wheels are moving out from the straight ahead position when for example torque is applied. Good possibility something is either loose or worn. Sometimes this can be seen when power braking the vehicle with the brakes applied in forward and reverse.
Old Jun 18, 2018 | 03:13 PM
Roz's Avatar
Roz
Eddyk thanks for that info I'm going to have that looked at and keep you posted
Old Jun 18, 2018 | 03:15 PM
Roz's Avatar
Roz
Hanky thanks will check into that also
Old Jun 19, 2018 | 04:14 PM
Roz's Avatar
Roz
Shop said that front left control arm bolts have rusted through the subframe that's causing the steering to pull...they said subframe lower control arm needs replacing and it'll be $1800
Old Jun 19, 2018 | 04:46 PM
avisitor's Avatar
Check for open recalls on your vehicle
Hopefully there is one on lower control arm or subframe
Good luck
Old Sep 19, 2018 | 07:36 PM
smedleyludlow's Avatar
I think I would put my own eyes on it or maybe get a second opinion. make them show you where the bad parts are on the control arm.
kinotib
Feb 12, 2019 07:20 AM
rosspointon
Sep 30, 2015 08:47 AM
nateb22
Mar 12, 2010 09:35 AM
aznjohn
Jun 14, 2009 07:34 AM
knuckles
Apr 9, 2007 09:15 AM
