06 v6 limp mode/throttle body issues
Old May 19, 2018 | 03:18 PM
christian.mumley's Avatar
Default 06 v6 limp mode/throttle body issues
I have a 2006 Sonata v6, recently while driving the car stopped accelerating. Now it does not go above 10mph, and idles at 1500 rpm, when usually it was around 500-600 rpm. Also the ESC mode was instantly turned off. I hooked it up to a code reader at home and got the following: P1295, P0638 and P2106. I took the throttle body off and looked at the sensor on the right side and it looked fine. Other than that, I don’t know what could be wrong
Old Mar 30, 2019 | 01:53 AM
Vaniłła Zilla's Avatar
Default Hey buddy still looking for an answer ?
I believe I’ve found the issue to this problem . It’s caused by a clogged fuel pump filter . Hyundai states the fuel pump filter is an internal part but it can be replaced without the entire pump this solved the issue in my 2006 3.3 v6 . Symptoms prior were hard starts and rare limp home mode .
Old Jul 1, 2020 | 03:47 PM
Nick Byrne's Avatar
Default Did you fix this issue? I have all 3 off the same codes and esc off light.
Please let me know if you fixed this issue and what fixed it
Midwalestucson
Apr 1, 2015 03:45 AM
south20345
Feb 28, 2012 10:40 AM
ludwigs32
Feb 28, 2012 10:17 AM
dleo85
Apr 3, 2011 10:38 AM
Susana8
Apr 1, 2008 06:58 AM
