Passenger side headlight won't work
I have a 2006 Hyundai sonata the passenger side headlight won't work. I have checked the relay and fuses. I have even changed the bulb. The high beams work and the low beam on the driver's side works just not the passenger side. I'm not sure what else to do. Any help would be greatly appreciated!!!!!! 😀
Look at the connectors and see if there is corrosion.
If there is then clean it up.
Take a test light .. hook up one end to neg or ground of the battery ..
take the pointy part and touch the connector.
If it lights up then there is 12 volts or power going to the bulb
If it doesn't light up then there is no power to the bulb and you need to trace the wire.
Now put the other end on positive or power side of battery ...
Probe the connector again
If it lights up then there is a good ground
If it doesn't light up then the connector is missing the ground and you need to trace the wire
Start there and then from the results .. can find the next step
VINN07
Jun 11, 2017 10:28 PM
ilovedude
Dec 3, 2007 03:03 PM
