Engine Oil Leak & Shaft Replacement
Old May 31, 2011 | 05:54 PM
Riya's Avatar
Exclamation Engine Oil Leak & Shaft Replacement
Hi,
I saw there was some oil leaking and took it in to a shop and they said that it's the engine oil and that it would cost about $425 to replace the shaft on the left side..
Does this make sense?? Any help would be appreciated!
p.s - the engine light is Not on..
2000 Hyundai Tiburon
Driven only about 155k
Old May 31, 2011 | 08:44 PM
Try a $10 axle seal, and clean up the stub on the CV joint that the seal rides on, and refill trans oil to proper level.
Or are we talking a ripped/torn axle boot ?? In the event of the boot... go to Hyundai and buy an inner and outer boot kits and re-boot the axle (provided it is still Hyundai made axle),, dont forget to install fresh clean grease to the joints..
Old Jun 1, 2011 | 11:47 AM
Riya's Avatar
Thanks for your reply.
I took it to Meineke and they said it was the trans fluid and that it was over-filled.. I'm not sure WHO would have over-filled it?? I had an oil change done just a little while ago but that was just an oil change.. nothing to do with trans fluid ..
They said they would have to replace the box first and check if that fixes the problem - quoted approx $200..
BRollins
Mar 8, 2014 01:00 PM
amy_bsnl
Sep 16, 2009 01:49 AM
victorpage
Jun 21, 2009 09:52 PM
tallwest
Nov 1, 2008 10:47 AM
Billman
Aug 21, 2007 07:52 AM
