2016 1.6l rebuild
Old Jan 7, 2023 | 06:43 PM
skyler's Avatar
Default 2016 1.6l rebuild
Does anyone know where to find a rebuild kit for the engine and trans and turbo of a 2016 Tucson with the 1.6l turbo?
Old Jan 8, 2023 | 06:55 AM
Do you have the equip to do a real rebuild ?
Just replacing parts is not a rebuild without actually measuring for wear on certain parts and performing certain procedures.Could be spending time and $$ and not correcting the real problem .
Could there be some info you could have shared with us that leads you to feel a rebuild is required?
An example; special balancing equipment is REQUIRED, when doing work on turbos that spin at very high RPMs.
Old Jan 8, 2023 | 07:02 AM
skyler's Avatar
yes I do have equipment, engine has 125k with no major repairs till now. I’m a marine diesel mechanic. The engine has massive oil loss via blow by on the piston rings as well as full of sludge, also a metallic stapling come if from the false train. The turbo also needs to be rebuilt or replaced as it also has oil blow by and compressor wheel does not spin freely. As well as lots of play in the bearing
Old Jan 8, 2023 | 12:11 PM
As an experienced tech, no need to go any further with the need for measuring cyl bore and ring clearances.
Also , from experience, your best bet is to stay with OEM.
There are some aftermarket suppliers that offer various combinations of assorted parts depending on what you want to overhaul.
Some are ,,,,,,,,,,,,OK and some ,,,,,,,,oh well. Sounds like it was neglected as far as regular maintenance was concerned with a lot of sludge.
You have your work cut out for you, have a good one.
As you know, the engine should be allowed to idle a few minutes before shutdown and I would suspect that was not considered by previous owner which would contribute to turbo problems. What do you think?
Old Jan 8, 2023 | 04:26 PM
skyler's Avatar
yes I agree I’m trying to stay oem with it but I want to do full rebuild replace everything, and I’ve had my fair share of full rebuilds so it’s not too bad, but yes it was definitely neglected
Old Jan 9, 2023 | 08:32 AM
If circumstances permit, we would appreciate hearing from you as to how the rebuild went , thanks.
Goncntry13
Apr 21, 2021 06:02 PM
hullj18
Jan 9, 2020 07:17 PM
josepepper
Dec 25, 2016 11:17 AM
mark0006
Feb 13, 2015 12:00 PM
skateoutloud92
Jul 20, 2010 03:21 PM
