Fuel pump in the tank???
Old Jun 8, 2023 | 09:48 PM
BrentJOk's Avatar
Default Fuel pump in the tank???
2014 2.4l gdi with a high pressure pump on top, but does it also have a lift pump in the tank? If not, why is there a fuel pressure relay, and what is in the tank opening on top? The car died while driving today. No codes were thrown. I suspect fuel pump, but cannot find a sure way to verify the high pressure pump is out. My car has the lifetime engine warranty. Anyone know if a fuel pump is covered?
Old Jun 9, 2023 | 05:30 AM
A capable scan tool is required to diagnose fuel pressure. Hi press pump when operating correctly can produce pressures in excess of 3000 psi and can be dangerous to work on without the proper equip.
Old Jun 9, 2023 | 08:20 PM
BrentJOk's Avatar
I pulled it. It's a pump. Dealer want $800+. Internet wants $370. After getting numbers and digging, I found the part numbers below.
Pump assembly is 31110-2s600. The pump itself is 311112w050. Under $30!!!!!
Old Jun 10, 2023 | 05:59 AM
Let;s hope your diagnosis was correct.
There is a lot to know about just how a hi pressure fuel pump works .
makowski306
Nov 7, 2017 03:19 PM
catchuyet
Feb 28, 2012 09:04 AM
johngotts
Apr 11, 2010 12:27 PM
sanjayags
Oct 26, 2007 02:03 PM
bobsod
Jul 14, 2006 12:00 PM
