2004 Hyundai Santa Fe-Engine Question
Old 02-03-2017, 08:33 PM
Niyckiey's Avatar
Default 2004 Hyundai Santa Fe-Engine Question
Replaced water pump, drive belt, timing belt and pulleys, wires, plugs, thermostat, radiator. My question: the top radiator hose is hot, the bottom cold. Engine guage is normal. Is this normal? If not, how do I check to see if I have a collapsed hose, should the bottom hose be ice cold? I am afraid to keep engine running for too long, don't want to ruin the engine. Any suggestions would be helpful. Thank you
Old 02-04-2017, 06:49 AM
koza's Avatar
My bet is on thermostat,that does not open.Installed in reverse order (just possibility),or cheap aftermarket ones.They don't work sometimes. My guess,I never had this problem.
Prince Edward
12-17-2016 09:14 AM
glassfern53
09-05-2015 02:47 PM
zerosoma
06-21-2012 09:37 PM
tommyvegas76
08-30-2011 01:54 PM
04Sonataowner
06-21-2011 05:27 PM
Quick Reply: 2004 Hyundai Santa Fe-Engine Question
