P0340 error
P0340 error
Dear sir
I have Hyundai accent 2010 1600cc. The timing belt was broken and it's broke 2 valves after I replaced it the car stated normally after about 3 to 5 minutes the engine was showdown by itself. Then I tried to started the engine but the engine can't stated ( die) I used the OBDII show P0340 I replaced the sensor can't start too I checked all the wiring and the voltages every thing looks fine. What should I do ? Please advise,
kind regards
kind regards
The code is providing some direction, however, we need to verify if ,
we have spark available
do we have fuel available , remove one spark plug and see if it is wet or dry.
If wet,could be fuel question (quality) or no spark condition
If dry, no fuel condition
Which do you have?
Which do you have?
Which do you have?
Which do you have?
got fuel and spark
gredman
03-06-2020 09:59 PM
