Screen turned black — radio still works
Old 09-27-2019, 12:31 PM
Jessica Marie's Avatar
Default Screen turned black — radio still works
I have a 2011 Sonata Limited. Yesterday while I was driving the display just shorted out and turned black and hasn’t come on since. My radio still works and I can use all the buttons on my radio, but Bluetooth won’t connect and the review camera won’t come on. I haven’t damaged it/spilled anything on it. I tried pressing the reset button and pulling out the fuse and plugging it back in, but both options have done nothing. I’m really trying to avoid the high dealer costs, so I’m hoping someone has had experience with this in the past and can lead me to a solution I can do myself. Thanks!
Old 09-28-2019, 11:45 AM
Something you might try,
You might lose any programmed features like power seat, mirrors, radio stations etc.
If you or have someone remove the battery negative cable from the battery and then remove the positive cable from the battery and hold the two cable ends together contacting each other for a few minutes then reconnect the positive cable end back to the battery positive post , then reconnect the negative cable end back on to the negative cable post. . Turn on the ignition and see if the screen comes back on If it takes care of the problem, fine. When you start the vehicle allow the vehicle computer to reset the idle speed by not touching the accelerator pedal for a few minutes.Let us know if this took care of the problem.
Old 11-11-2020, 03:33 PM
Dave Taylor's Avatar
Default Did it fix the issue?
[hi, I have the same problem. Did you ever get it fixed?
QUOTE=Jessica Marie;57008]I have a 2011 Sonata Limited. Yesterday while I was driving the display just shorted out and turned black and hasn’t come on since. My radio still works and I can use all the buttons on my radio, but Bluetooth won’t connect and the review camera won’t come on. I haven’t damaged it/spilled anything on it. I tried pressing the reset button and pulling out the fuse and plugging it back in, but both options have done nothing. I’m really trying to avoid the high dealer costs, so I’m hoping someone has had experience with this in the past and can lead me to a solution I can do myself. Thanks![/QUOTE]
Old 07-06-2021, 02:24 PM
BoinLV's Avatar
Worked well for me!
Many thanks, hanky!
Old 07-07-2021, 07:55 AM
Thank you for the update, always nice to get good news.
Old 11-28-2021, 04:59 PM
jqpicc09's Avatar
Jessica, did you ever figure out how to fix your Sonata? I have a 2011 Sonata with the exact same issue.
Old 11-29-2021, 09:00 AM
jqpicc09's Avatar
Dave Taylor, I also have the same problem. Did you ever figure out a solution?
[/QUOTE]
Old 02-21-2022, 09:58 AM
cwest65's Avatar
I have a 2012 sonata same problem this did not fix mine what else could be the cause?
Old 02-21-2022, 05:38 PM
Did you look for a blown fuse?
Old 02-21-2022, 06:28 PM
cwest65's Avatar
Default Black screen
If it is the yellow one yes still didn't work
KyndleK
06-14-2021 02:30 AM
princeinflorida
08-04-2016 10:27 PM
waxman62
07-31-2013 05:26 PM
nevis111
05-18-2010 04:25 PM
bfkf95
03-18-2010 11:29 AM
Quick Reply: Screen turned black — radio still works
