Timing belt whine after replacement 2010 elantra
Old 04-16-2017, 11:41 PM
Milos's Avatar
Default Timing belt whine after replacement 2010 elantra
I replaced the timing belt and water pump in my 2010 elantra, now there is a slight whine from the timing belt, confirmed from timing belt. I made sure and double checked that the tension is correct and within the white marked window. Not from any pulleys. What could this be? Could it be the new gates belt?
Old 04-17-2017, 08:23 AM
avisitor's Avatar
From your description, what else can it be??
Old 08-11-2017, 05:32 PM
TurboRev's Avatar
Did you replace it with an OEM Hyundai timing belt?
Old 08-11-2017, 07:01 PM
avisitor's Avatar
Did you also change the idler and tensioner pulleys??
Old 06-04-2020, 07:53 AM
flykol's Avatar
Some time belts have direction arrow. The one for my accent did not Make a doing recording and post link. All plastic covers in right place. When you replace worn idlers, then you hear new sounds that we’re hidden
Moondog66
07-22-2016 11:23 PM
rm125chris
07-05-2009 01:00 AM
miniwangja
06-12-2009 05:49 PM
Robert
10-19-2008 11:08 AM
tim.penfold
03-20-2008 02:32 PM
Quick Reply: Timing belt whine after replacement 2010 elantra
